Старый 12.09.2016, 18:11   #1
organicax: Basic Kanban rule setup – event manual
Источник: https://organicax.com/2016/09/12/bas...-event-manual/
In an earlier post we had a look at an automatic event Kanban setup.  There could be some operational challenges with an automatic event Kanban if orders are often changed because it would mean the Kanban would be out there but might have to be changed. You could add an operational step to create the Kanban once the sales order has been confirmed for example. In this case you could create a manual event Kanban.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: Basic Kanban rule setup – event automatic Blog bot DAX Blogs 0 10.09.2016 02:25
organicax: WMS Packing compile of setup posts. Blog bot DAX Blogs 0 26.07.2016 16:11
organicax: Basic inventory unit setup for an item Blog bot DAX Blogs 0 30.04.2016 03:35
organicax: Basic constraint based configuration product and model setup. Blog bot DAX Blogs 0 28.03.2016 22:12
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
Часовой пояс GMT +3, время: 10:25.
