Старый 17.09.2016, 21:14   #1
organicax: Basic counting journal process
Источник: https://organicax.com/2016/09/17/bas...urnal-process/
If you are an inventory based business then you will at some point need to count inventory. There are a number of business strategies on how to approaching counting depending on the nature of the products. For example high turn over products you might want to count more frequently then low turn-over products. Once you have you strategy worked out then you can setup a counting journal and use different means to filter and look for the items you want to count. The counting journal in AX just gives you a mechanism to record the result of a count.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning, Warehouse management
organicax: Basic process for foreign currency revaluation on an account Blog bot DAX Blogs 0 25.03.2016 05:29
organicax: Basic request for quotation process Blog bot DAX Blogs 0 15.03.2016 04:48
organicax: Basic process of handling item requirement on a project. Blog bot DAX Blogs 0 14.03.2016 22:11
Microsoft Dynamics CRM Team Blog: Using the Business Process Flow Designer Blog bot Dynamics CRM: Blogs 0 24.10.2013 05:13
Часовой пояс GMT +3, время: 02:33.
