Старый 17.12.2019, 02:30   #1
crmtipoftheday: Tip #1317: Make lead qualification better with Power Automate
Источник: https://crmtipoftheday.com/1317/make...ower-automate/
You work on a lead in Dynamics 365–you have several conversations and enter some notes.
After you qualify the lead, the activities show up on the account or contact record that was created in the qualification process, but the notes are left behind on the lead.
Power Automate to the rescue!
Create a Flow that runs on create of a contact (or account if you are qualifying leads to accounts).
Action 1: Get lead record (to get all details)
Action 2: Condition: If originating lead equals null, terminate
Action 3: List records — get notes where objectID equals contact originating lead.
Action 4: condition: length(outputs(‘List_records’)?[‘body/value’]) is greater than 0 (does #3 return any notes)?
If yes, Apply to each and update the note, setting the regarding to the contact.
End result? Your lead notes are now linked to the newly created contact.
Cover photo by Min An from Pexels
crmtipoftheday: Tip #1293: Make case customer a contact Blog bot Dynamics CRM: Blogs 0 12.08.2019 16:11
crmtipoftheday: Tip #1282: Dynamics 365 customization & configuration using the Power Platform Blog bot Dynamics CRM: Blogs 0 19.07.2019 17:12
crmtipoftheday: Tip #1229: Use math to make your chart look good Blog bot Dynamics CRM: Blogs 0 08.03.2019 18:22
crmtipoftheday: Tip #1096: Apply Power BI theme to regular charts Blog bot Dynamics CRM: Blogs 0 03.04.2018 05:35
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
Часовой пояс GMT +3, время: 11:25.
