Старый 15.04.2003, 16:06   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
DSN системный или пользовательский?
The DSN (ODBC data source) might have been set up as a user DSN. The Axapta Server Manager (and thereby the Axapta Object Servers) will by default run as system user, without access to users environment. Access to the database should be provided by System DSN to make it available to all users of the NT system. Use Settings/Control Panel/ODBC data sources to create an appropriate System DSN to use, and revise configuration to use this
odbc, ошибка, установка, ax3.0
Оценка производительности Axapta Object Server vesna dba DAX: Администрирование 15 29.06.2009 13:53
Запуск Axapta 3.0 Object Server Manager в качестве консольного приложения gl00mie DAX: Администрирование 2 15.11.2007 11:12
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
No Navision Axapta Object server could be located using current client configuration AKIS-Falcon DAX: Администрирование 7 08.07.2005 14:52
Часовой пояс GMT +3, время: 07:04.
