Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 27.03.2009, 10:18   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от em# Посмотреть сообщение
My question is if there is a way to enable permissions for Temp tables without modifying the application.
What's the purpose of setting permissions on temporary tables? They're always populated by code, and the originating data is usually taken from "real" tables or somehow produced by the code, so you can always perform an access validation in your code:
if (isTableUserEnabled( tablenum(CustTable) ))
    // populate temp table
else
    throw error( "@SYS60037" ); // Access denied
Besides, you never know where this or that temp table can be used. If an arbitrary temp table has a suitable set of fields then it's sometimes preferable to use it in your custom form/report then to create a new temp table. E.g. lots of standard reports in the localization for Eastern Europe use just a couple of temporary tables - both in Accounts Payable and Accounts Receivable modules. Obviously in this case it's more flexible and robust to validate access by security keys on menu items.
kamalblogs: Setting default object owner as Object creator in Window server 2008 for AIF in Dynamics Ax Blog bot DAX Blogs 1 04.08.2010 14:24
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
Inside Dynamics AX 4.0: Security Coding Blog bot DAX Blogs 0 31.10.2007 23:40
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 18:06.
