Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 27.03.2009, 19:42   #9
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Yes, when you make your security setup since it's a temporary table it isn't shown in the list of tables in the "tables node" . So in order to get access to your temp table it is enough to set any rights to the node InventTables.
PS If any of the answers above helped you we have a button "Thanks" just below every post. Welcome to AxForum!
За это сообщение автора поблагодарили: em# (1).
kamalblogs: Setting default object owner as Object creator in Window server 2008 for AIF in Dynamics Ax Blog bot DAX Blogs 1 04.08.2010 14:24
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
Inside Dynamics AX 4.0: Security Coding Blog bot DAX Blogs 0 31.10.2007 23:40
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 02:04.
