Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 27.03.2009, 12:59   #5
em# is offline
em#
Thanks All for the reply.
The table we want to allow permissions - tmpInventTransWMS - has a Security key on SYS layer.
The error below can be reproduced in Purchase orders screen, by selecting a purchase line, click Inventory button-> Registration.
“Not enough rights to use table 'Registration/picking' (TmpInventTransWMS).”
So, what security setup needs to be done for a particular user group to avoid this error? If temp tables have Security keys on SYS layer it is possible that there’s a way to manage them?
We can enable access to the temp table by setting access for the Security key the table is attached (in particularly for InventTables key), but it will enable some extra permissions to the user group.
Once again, thanks for help.
kamalblogs: Setting default object owner as Object creator in Window server 2008 for AIF in Dynamics Ax Blog bot DAX Blogs 1 04.08.2010 14:24
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
Inside Dynamics AX 4.0: Security Coding Blog bot DAX Blogs 0 31.10.2007 23:40
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 12:59.
